I have an idea for a project- how do i build it with Circuito.io?
The best way to start building your project is to divide it into these 3 basic steps:
  1. Input is what activate your project. It can be a button you press, a temperature sensor or any other component you want from the input list you get once you press the “Add Input” button (Yellow)
  2. Output is what you want your project to do (for example- turn on an LED light). Simply press the “Add output” button (purple).
  3. Controller (the blue button) is what connects between the Input and the Output.
Congratulations! You now have a project :slight_smile: you can also change the power supply (grey button) or make it a smart IoT project that connects to the internet (green button)
You can also view our detailed guide on how to build a project with examples and ideas for projects.
