The answer gives me a different power source than the one i requested
Some components simply don’t work well with others. For example; a DC motor cannot be powered with only a USB cable connection since it requires a higher voltage; An Arduino Mini doesn’t have a USB connection and therefore cannot be powered by USB.
if the power source you choose is not compatible with the components you want, will offer an alternative that will do the job
