What is the function of this code
Hi
I’m not sure which part you want explained, so here’s the whole lot! :slight_smile:
The lines that start with void are functions that don’t return a value (their return type is void - nothing).
Overview
There are at least two functions in most Arduino programs. The first you see there is called setup and it is run/invoked once at the start of the program (when you supply power or press the reset button). The other function (loop) is called over and over and over in an endless loop.
Outside these functions, the Arduino can be interrupted by certain events. This might be buttons being pressed, or counters inside the circuitry. We can attach our own functions to these interrupts and do something in response to the event.
Now to the details:
In setup, the program starts serial communications at a baud rate of 9600. This allows you to see output that your code prints to serial in the serial monitor built into the Arduino IDE.
It then sets the mode of the pin numbered with the value of pin (which we can’t see in your screenshot) as an input pin meaning we intend to read the value of it rather than write a value to it.
It then attaches a function called count_pulse to pin 0 to be invoked/called when the state changes from low to high.
Looking at the interrupt function, I see that there’s a syntax error in the voidcount_pulse() line. A space is missing after void. It should be void count_pulse(). The function simply increments (adds one to) the value of the pulse variable.
The loop function sets pulse to 0 before enabling interrupts with the call to interrupts() and then delaying (sleeping) for 1000 milliseconds (one second). It then disables interrupts with a call to noInterrupts() before printing the number of pulses that were counted by the count_pulse function whilst it was sleeping. Then it does the same thing all over again. :slight_smile:
