Can I use my own code?
After you finish assembling your circuit, we suggest that you download the code generated by, unzip it, and upload it to your Arduino to make sure that everything is connected properly. Once you do this and you see that everything is set up properly, you can start modifying the code, using the pre-set functions and the libraries that were sent with the code from
