Need help with how to use circuito.io with a project you are working on? Use this category to get feedback from the circuito.io team as well as other members of the community.
need to make a system that has a sound sensor that tells an Xbee s-1 to talk to a receiver xbee s1 and an arduino controls a solenoid and a drill motor. any help would be appreciated. I can provide details as well
Good day, Circuito team,
I just wonder if you can help me build Home Automation, I have two garage doors and main entrance gate to my house, most of the time myself and my kids sometimes we often forget to close either the main gate or the garage door overnight, we live in an area that is not safe here in South Africa,
Main Gate works with a remote, I will like to use ESP8266 relay module (on one of the GPIO pin and wire a remote to relay pin NO AND COM ) for opening and closing the gate and also have Magnetic Door Switch connected to other GPIO pins for status (open and close using Led widget(Blynk App) to see changes color to red for open and green for closed or just text on a Blynk LCD) with notifications to notify me if I leave my gate opened for more than 10 minutes and also be able to switch off notifications if am busy near the Main Gate.
Garage doors we have to have a two Magnetic Door Switch one for each side also be able to know if I left the Garage door opened same as the Main Gateif it happens that I leave Garage doors for example (the left or right door is open or closed with notifications to notify me if I leave one of the garages opened for more than 10 minutes and also be able to switch off the notification if am busy in the Garage.
**Car parked notification just status only just to know if the is a car in the garage by mean of having IR sensor on the front of each side, so when a car is parked the IR write status (the is Car in the left or Both side through A led widget that changes( Blynk LCD) or Text color to red for no Car’ and green the is the car garage
last but no list
Garage Door Light: I want to use LDR to switch On the light when it gets dark on one of the Relay
I have
· ESP8266 Nodemcu
· Magnetic Door Switch x for the two garage doors
· IR Sensor x 2 inside the Garage for car Status
· Magnetic Door Switch x 1 for Main Gate entrance
. LDR x 1
. Relay module x 3
I will be happy if you can help with a Code for this Project
I have attached my Project: https://www.circuito.io/static/reply/index.html?solutionId=5e6a90542329930030db5dac&solutionPath=storage.circuito.io
hi im failing to connect more than 35 components on design platform of circuit io
