An arcade button for raspberry pi 3
Hi can you guys who are working at circuito ad a arcade button to the raspberry pi 3.
Currently circuito.io support only arcade button with a built-in LED that requires 5v voltage for the LED. (raspberry pi 3 cannot provide enough power for this type of button)
Soon we will add an arcade button without a built-in LED, so it will be supported also on raspberry pi 3
Meanwhile you can use this wiring, which will work for an arcade button and raspberry pi 3
Maayan
