Hi, I´m willing to make an arduino based irrigation system
what kind for help you need??
Hi hammoude94,
I just begun with the project.
Thank you very much for your kind offer. Is it possible to get from circuit io the file to make the printed board?
I´m really newbie here .
Thnaks much!
sorry i don’t know.
i did not to try to do this.
and i didn’t use circuit io alote.
Hi Pedrito, I’m not exactly sure I understood your question. If you know which components you want to use for the project, then you can select them on circuito.io and get a breadboard wiring diagram, and a test code. At the moment, our app doesn’t design the printed circuit board, but we’re working on it, in circuito.io pro.
You can use this tutorial we made - https://www.circuito.io/blog/diy-irrigation-system/ as a reference for your project. If you have any more questions, don’t hesitate to ask.
