#include “Arduino.h”
#include “LED.h”
#define LEDG_PIN_VIN 5
#define LEDR_PIN_VIN 6
#define MQ3_5V_PIN_AOUT A3
LED ledG(LEDG_PIN_VIN);
LED ledR(LEDR_PIN_VIN);
Serial.println(“start”);
menuOption = menu();
if(menuOption == '1') {
// LED - Basic Green 5mm - Test Code
// The LED will turn on and fade till it is off
for(int i=255 ; i> 0 ; i -= 5)
ledG.dim(i); // 1. Dim Led
delay(15); // 2. waits 5 milliseconds (0.5 sec). Change the value in the brackets (500) for a longer or shorter delay in milliseconds.
ledG.off(); // 3. turns off
else if(menuOption == '2') {
// LED - Basic Red 5mm - Test Code
ledR.dim(i); // 1. Dim Led
ledR.off(); // 3. turns off
else if(menuOption == '3')
// Disclaimer: The Alcohol Gas Sensor - MQ-3 is in testing and/or doesn't have code, therefore it may be buggy. Please be kind and report any bugs you may find.
char menu()
Serial.println(F("(1) LED - Basic Green 5mm"));
Serial.println(F("(2) LED - Basic Red 5mm"));
Serial.println(F("(3) Alcohol Gas Sensor - MQ-3"));
while (!Serial.available());
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Testing LED - Basic Green 5mm"));
else if(c == '2')
Serial.println(F("Now Testing LED - Basic Red 5mm"));
else if(c == '3')
Serial.println(F("Now Testing Alcohol Gas Sensor - MQ-3 - note that this component doesn't have a test code"));
return 0;
time0 = millis();
return c;
Circuito.io is an automatic generator of schematics and code for off
the shelf hardware combinations.
Copyright © 2016 Roboplan Technologies Ltd.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
In addition, and without limitation, to the disclaimers of warranties
stated above and in the GNU General Public License version 3 (or any
later version), Roboplan Technologies Ltd. (“Roboplan”) offers this
program subject to the following warranty disclaimers and by using
this program you acknowledge and agree to the following:
THIS PROGRAM IS PROVIDED ON AN “AS IS” AND “AS AVAILABLE” BASIS, AND
WITHOUT WARRANTIES OF ANY KIND EITHER EXPRESS OR IMPLIED. ROBOPLAN
HEREBY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING BUT
NOT LIMITED TO IMPLIED WARRANTIES OF MERCHANTABILITY, TITLE, FITNESS
FOR A PARTICULAR PURPOSE, NON-INFRINGEMENT, AND THOSE ARISING BY
STATUTE OR FROM A COURSE OF DEALING OR USAGE OF TRADE.
YOUR RELIANCE ON, OR USE OF THIS PROGRAM IS AT YOUR SOLE RISK.
ROBOPLAN DOES NOT GUARANTEE THAT THE PROGRAM WILL BE FREE OF, OR NOT
SUSCEPTIBLE TO, BUGS, SECURITY BREACHES, OR VIRUSES. ROBOPLAN DOES
NOT WARRANT THAT YOUR USE OF THE PROGRAM, INCLUDING PURSUANT TO
SCHEMATICS, INSTRUCTIONS OR RECOMMENDATIONS OF ROBOPLAN, WILL BE SAFE
FOR PERSONAL USE OR FOR PRODUCTION OR COMMERCIAL USE, WILL NOT
VIOLATE ANY THIRD PARTY RIGHTS, WILL PROVIDE THE INTENDED OR DESIRED
RESULTS, OR OPERATE AS YOU INTENDED OR AS MAY BE INDICATED BY ROBOPLAN.
YOU HEREBY WAIVE, AGREE NOT TO ASSERT AGAINST, AND RELEASE ROBOPLAN,
ITS LICENSORS AND AFFILIATES FROM, ANY CLAIMS IN CONNECTION WITH ANY OF
THE ABOVE.
we used that code. But arduino ide said "아두이노:1.8.13 (Windows Store 1.8.42.0) (Windows 10), 보드:“Arduino Uno”
Firmware:4:10: fatal error: LED.h: No such file or directory
#include “LED.h”
compilation terminated.
exit status 1
LED.h: No such file or directory"
well… I can’t understand this problem…
could you tell me about this problem’s method?
