Automatic regulation of ambient conditions in a greenhouse
I want to create a system to open and close the green house vents and side curtains using Arduino uno,DHT11,16x2 LCD and continuous rotation micro-servo motor.I want to control the level of humidity and temperatures in the greenhouse in that when the temperatures are high and humidity is low the sensor detects and sends that information to the Arduino and the Arduino sends an output command to the motor to raise the vents and the side curtains up and lower the side curtain and the vents when the temperature decreases and humidity rises
Hi there,
did you create your circuit with circuito.io?
It seems we have all the components you’d like to use and our sample circuit will give you th head start you need.
If you then have further questions on how to build out the code logic, we are here.
Yana.
