Hi, I’m a student and I do not know anything about arduino, I’m creating a project on an automated greenhouse, I have almost everything ready, I only need the sensors that send the information to a mobile app, all this with solar energy, please, I need help , do not know what this project really means to me and how important it is, I could give something in return to help me, please help me, any message or help is appreciated.
Hi Nehuel,
To proceed building your circuit with circuito.io - drag and drop onto the canvas the components you wish to use - and circuito.io will automatically create a wiring diagram for you, the list of all the parts you need to buy (you may choose to buy from us or from a local provider) and sample code that will give you an example of how to work with each component individually.
In your case, you’ll need a solar panel as your power source, your selection of sensors and an ESP8266 to connect your circuit to wifi to be able to send the collected data to be viewed via a mobile app.
To view the data online - you can use the solution built in with circuito.io - using a Freeboard dashboard, or alternatively you can try using a tool like Blynk to create your dashboard, in which case you’ll need to integrate Blynk code into the circuito.io code.
We’re here for further assistance,
Yana.
