So I have two sets of working codes. One for a BMP280 and one for a AM2302. I have them both wired correctly to an Arduino Nano and can get them both to run on separate sketches.
My goal is to add the BMP280 coding to my AM2302 code… but have no clue what to/how to do that! Ideally they would run at the same time… but am also okay with having two separate functions like the AM2302 code could allow.
This is the BMP280 code:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
Serial.println(F(“BMP280 test”));
if (!bmp.begin(0x76)) {
Serial.println(F(“Could not find a valid BMP280 sensor, check wiring!”));
while (1);
/* Default settings from datasheet. /
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, / Operating Mode. /
Adafruit_BMP280::SAMPLING_X2, / Temp. oversampling /
Adafruit_BMP280::SAMPLING_X16, / Pressure oversampling /
Adafruit_BMP280::FILTER_X16, / Filtering. /
Adafruit_BMP280::STANDBY_MS_500); / Standby time. */
Serial.print(F(“Temperature = “));
Serial.print(bmp.readTemperature());
Serial.println(” *C”);
Serial.print(F("Pressure = "));
Serial.print(bmp.readPressure());
Serial.println(" Pa");
Serial.print(F("Approx altitude = "));
Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
Serial.println(" m");
Serial.println();
delay(2000);
This is the code for the AM2302:
#include “Arduino.h”
#include “DHT.h”
#define AM2302_PIN_SIG 2
DHT am2302(AM2302_PIN_SIG);
const int timeout = 3000; //define timeout of 3 sec
Serial.println(“start”);
am2302.begin();
menuOption = menu();
if(menuOption == '1') {
// AM2302 Humidity and Temperature Sensor - Test Code
// Reading humidity in %
float am2302Humidity = am2302.readHumidity();
// Read temperature in Celsius, for Fahrenheit use .readTempF()
float am2302TempC = am2302.readTempC();
Serial.print(F("Humidity: ")); Serial.print(am2302Humidity); Serial.print(F(" [%]\t"));
Serial.print(F("Temp: ")); Serial.print(am2302TempC); Serial.println(F(" [C]"));
char menu()
Serial.println(F("\nWhich component would you like to run?"));
Serial.println(F("(1) AM2302 Humidity and Temperature Sensor"));
Serial.println(F("(menu) Press 1 to activate Humidity and Temperature Sensor for 3 seconds\n"));
while (!Serial.available());
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Running AM2302 Humidity and Temperature Sensor"));
return 0;
time0 = millis();
return c;
