Arduino says that this program wasnt declared in scope.
Here’s the code:
#include “Arduino.h”
#include “DCMotor.h”
#include “Potentiometer.h”
#define DCMOTOR_PIN_COIL1 5
#define POTENTIOMETER_5V_PIN_SIG A3
DCMotor dcMotor(DCMOTOR_PIN_COIL1);
Potentiometer potentiometer_5v(POTENTIOMETER_5V_PIN_SIG);
Serial.println(“start”);
menuOption = menu();
if(menuOption == '1') {
// DC Motor - Hobby Motor Gear - Test Code
// The DC motor will turn on and off for 4000ms (4 sec)
dcMotor.on(200); // 1. turns on
delay(4000); // 2. waits 4000 milliseconds (4 sec). change the value in the brackets (4000) for a longer or shorter delay.
dcMotor.off(); // 3. turns off
delay(4000); // 4. waits 4000 milliseconds (4 sec). change the value in the brackets (4000) for a longer or shorter delay.
else if(menuOption == '2') {
// Rotary Potentiometer - 10k Ohm, Linear - Test Code
int potentiometer_5vVal = potentiometer_5v.read();
Serial.print(F("Val: ")); Serial.println(potentiometer_5vVal);
char menu()
Serial.println(F("(1) DC Motor - Hobby Motor Gear"));
Serial.println(F("(2) Rotary Potentiometer - 10k Ohm, Linear"));
while (!Serial.available());
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Testing DC Motor - Hobby Motor Gear"));
else if(c == '2')
Serial.println(F("Now Testing Rotary Potentiometer - 10k Ohm, Linear"));
return 0;
time0 = millis();
return c;
