So I was wondering if there is a way to download the image of the schematic after I have finished adding all the components. I don’t want to simply take a screecshot since the image won’t be as high res. Maybe thought a button could be added to download a high quality image
Hey!
Thanks for the suggestion! If you want higher resolution, I would recommend to zoom in on the circuit before you take the screenshot. In addition, you can save the URL of the circuit you planned in your bookmarks, or send it to yourself, so you can use it elsewhere or at another time. The specific URL (such as this one - https://www.circuito.io/app?components=513,360216,844727,2331989) will always generate the same circuit.
