Help with code (menu not declared)
#include “Arduino.h”
#include “PiezoSpeaker.h”
#include “SoilMoisture.h”
#define PIEZOSPEAKER5V_PIN_SIG 3
#define SOILMOISTURE5V_PIN_SIG A0
unsigned int piezoSpeaker5vHoorayLength = 6; // amount of notes in melody
unsigned int piezoSpeaker5vHoorayMelody[] = {NOTE_C4, NOTE_E4, NOTE_G4, NOTE_C5, NOTE_G4, NOTE_C5}; // list of notes. List length must match HoorayLength!
unsigned int piezoSpeaker5vHoorayNoteDurations[] = {8 , 8 , 8 , 4 , 8 , 4 }; // note durations; 4 = quarter note, 8 = eighth note, etc. List length must match HoorayLength!
PiezoSpeaker piezoSpeaker5v(PIEZOSPEAKER5V_PIN_SIG);
SoilMoisture soilMoisture5v(SOILMOISTURE5V_PIN_SIG);
Serial.println(“start”);
menuOption = menu();
if(menuOption == '1') {
// Piezo Speaker - Test Code
// The Speaker will play the Hooray tune
piezoSpeaker5v.playMelody(piezoSpeaker5vHoorayLength, piezoSpeaker5vHoorayMelody, piezoSpeaker5vHoorayNoteDurations);
delay(500);
else if(menuOption == '2') {
// Soil Moisture Sensor - Test Code
int soilMoisture5vVal = soilMoisture5v.read();
Serial.print(F("Val: ")); Serial.println(soilMoisture5vVal);
char menu()
Serial.println(F("(1) Piezo Speaker"));
Serial.println(F("(2) Soil Moisture Sensor"));
while (!Serial.available());
while (Serial.available())
    char c = Serial.read();
    if (isAlphaNumeric(c))
        if(c == '1')
			Serial.println(F("Now Testing Piezo Speaker"));
		else if(c == '2')
			Serial.println(F("Now Testing Soil Moisture Sensor"));
            return 0;
        time0 = millis();
        return c;
  • Circuito.io is an automatic generator of schematics and code for off
  • the shelf hardware combinations.
  • Copyright © 2016 Roboplan Technologies Ltd.
  • This program is free software: you can redistribute it and/or modify
  • it under the terms of the GNU General Public License as published by
  • the Free Software Foundation, either version 3 of the License, or
  • (at your option) any later version.
  • This program is distributed in the hope that it will be useful,
  • but WITHOUT ANY WARRANTY; without even the implied warranty of
  • MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
  • GNU General Public License for more details.
  • You should have received a copy of the GNU General Public License
  • along with this program. If not, see http://www.gnu.org/licenses/.
  • In addition, and without limitation, to the disclaimers of warranties
  • stated above and in the GNU General Public License version 3 (or any
  • later version), Roboplan Technologies Ltd. (“Roboplan”) offers this
  • program subject to the following warranty disclaimers and by using
  • this program you acknowledge and agree to the following:
  • THIS PROGRAM IS PROVIDED ON AN “AS IS” AND “AS AVAILABLE” BASIS, AND
  • WITHOUT WARRANTIES OF ANY KIND EITHER EXPRESS OR IMPLIED. ROBOPLAN
  • HEREBY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING BUT
  • NOT LIMITED TO IMPLIED WARRANTIES OF MERCHANTABILITY, TITLE, FITNESS
  • FOR A PARTICULAR PURPOSE, NON-INFRINGEMENT, AND THOSE ARISING BY
  • STATUTE OR FROM A COURSE OF DEALING OR USAGE OF TRADE.
  • YOUR RELIANCE ON, OR USE OF THIS PROGRAM IS AT YOUR SOLE RISK.
  • ROBOPLAN DOES NOT GUARANTEE THAT THE PROGRAM WILL BE FREE OF, OR NOT
  • SUSCEPTIBLE TO, BUGS, SECURITY BREACHES, OR VIRUSES. ROBOPLAN DOES
  • NOT WARRANT THAT YOUR USE OF THE PROGRAM, INCLUDING PURSUANT TO
  • SCHEMATICS, INSTRUCTIONS OR RECOMMENDATIONS OF ROBOPLAN, WILL BE SAFE
  • FOR PERSONAL USE OR FOR PRODUCTION OR COMMERCIAL USE, WILL NOT
  • VIOLATE ANY THIRD PARTY RIGHTS, WILL PROVIDE THE INTENDED OR DESIRED
  • RESULTS, OR OPERATE AS YOU INTENDED OR AS MAY BE INDICATED BY ROBOPLAN.
  • YOU HEREBY WAIVE, AGREE NOT TO ASSERT AGAINST, AND RELEASE ROBOPLAN,
  • ITS LICENSORS AND AFFILIATES FROM, ANY CLAIMS IN CONNECTION WITH ANY OF
  • THE ABOVE.
