Hello, I have no idea for what to do with code for when I try to verify, the code doesn’t work. Stuff like button and DCMDriver doesn’t work and such. please help me!
https://www.circuito.io/static/reply/index.html?solutionId=5bd670ebab8ee9002fce140e&solutionPath=storage.circuito.io
dear khaoskey,
kindly can you send a photo for your code and your circuit.
ok I will send a pic for my code and circuit
This is the code
#include “Arduino.h”
#include “DCMDriverL298.h”
#include “Button.h”
#include “IR.h”
#include “IRremoteInt.h”
#include “IRremote.h”
#define DCMOTORDRIVERL298_PIN_ENA 5
#define DCMOTORDRIVERL298_PIN_INT1 2
#define DCMOTORDRIVERL298_PIN_INT2 3
#define DCMOTORDRIVERL298_PIN_ENB 6
#define DCMOTORDRIVERL298_PIN_INT3 4
#define DCMOTORDRIVERL298_PIN_INT4 7
#define PUSHBUTTON_PIN_2 8
#define IR_PIN_OUT 9
DCMDriverL298 dcMotorDriverL298(DCMOTORDRIVERL298_PIN_ENA,DCMOTORDRIVERL298_PIN_INT1,DCMOTORDRIVERL298_PIN_INT2,DCMOTORDRIVERL298_PIN_ENB,DCMOTORDRIVERL298_PIN_INT3,DCMOTORDRIVERL298_PIN_INT4);
Button pushButton(PUSHBUTTON_PIN_2);
IR ir(IR_PIN_OUT);
Serial.println(“start”);
pushButton.init();
// initialize IR device
ir.init();
menuOption = menu();
if(menuOption == '1') {
// L298N Motor Driver Board Module - Test Code
//Start both motors. note that rotation direction is determined by the motors connection to the driver.
//You can change the speed by setting a value between 0-255, and set the direction by changing between 1 and 0.
dcMotorDriverL298.setMotorA(200,1);
dcMotorDriverL298.setMotorB(200,0);
delay(2000);
//Stop both motors
dcMotorDriverL298.stopMotors();
delay(2000);
else if(menuOption == '2') {
// Mini Pushbutton Switch - Test Code
//Read pushbutton state.
//if button is pressed function will return HIGH (1). if not function will return LOW (0).
//for debounce funtionality try also pushButton.onPress(), .onRelease() and .onChange().
//if debounce is not working properly try changing 'debounceDelay' variable in Button.h
bool pushButtonVal = pushButton.read();
Serial.print(F("Val: ")); Serial.println(pushButtonVal);
else if(menuOption == '3') {
// IR Receiver Diode - TSOP38238 - Test Code
//Receive IR code into irCode
long irCode = ir.detect();
// if a code was received print it to serial monitor, note that the code is of type long but printed in HEX
// Consider changing the if statment to something like: if(irCode == "YOUR IR CODE")
if(irCode)
Serial.print("0x");
Serial.println(irCode, HEX);
char menu()
Serial.println(F("(1) L298N Motor Driver Board Module"));
Serial.println(F("(2) Mini Pushbutton Switch"));
Serial.println(F("(3) IR Receiver Diode - TSOP38238"));
while (!Serial.available());
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Testing L298N Motor Driver Board Module"));
else if(c == '2')
Serial.println(F("Now Testing Mini Pushbutton Switch"));
else if(c == '3')
Serial.println(F("Now Testing IR Receiver Diode - TSOP38238"));
return 0;
time0 = millis();
return c;
Circuito.io is an automatic generator of schematics and code for off
the shelf hardware combinations.
Copyright © 2016 Roboplan Technologies Ltd.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
In addition, and without limitation, to the disclaimers of warranties
stated above and in the GNU General Public License version 3 (or any
later version), Roboplan Technologies Ltd. (“Roboplan”) offers this
program subject to the following warranty disclaimers and by using
this program you acknowledge and agree to the following:
THIS PROGRAM IS PROVIDED ON AN “AS IS” AND “AS AVAILABLE” BASIS, AND
WITHOUT WARRANTIES OF ANY KIND EITHER EXPRESS OR IMPLIED. ROBOPLAN
HEREBY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING BUT
NOT LIMITED TO IMPLIED WARRANTIES OF MERCHANTABILITY, TITLE, FITNESS
FOR A PARTICULAR PURPOSE, NON-INFRINGEMENT, AND THOSE ARISING BY
STATUTE OR FROM A COURSE OF DEALING OR USAGE OF TRADE.
YOUR RELIANCE ON, OR USE OF THIS PROGRAM IS AT YOUR SOLE RISK.
ROBOPLAN DOES NOT GUARANTEE THAT THE PROGRAM WILL BE FREE OF, OR NOT
SUSCEPTIBLE TO, BUGS, SECURITY BREACHES, OR VIRUSES. ROBOPLAN DOES
NOT WARRANT THAT YOUR USE OF THE PROGRAM, INCLUDING PURSUANT TO
SCHEMATICS, INSTRUCTIONS OR RECOMMENDATIONS OF ROBOPLAN, WILL BE SAFE
FOR PERSONAL USE OR FOR PRODUCTION OR COMMERCIAL USE, WILL NOT
VIOLATE ANY THIRD PARTY RIGHTS, WILL PROVIDE THE INTENDED OR DESIRED
RESULTS, OR OPERATE AS YOU INTENDED OR AS MAY BE INDICATED BY ROBOPLAN.
YOU HEREBY WAIVE, AGREE NOT TO ASSERT AGAINST, AND RELEASE ROBOPLAN,
ITS LICENSORS AND AFFILIATES FROM, ANY CLAIMS IN CONNECTION WITH ANY OF
THE ABOVE.
Sorry I did some research and it still doesn’t work with the new settings I put up
Here is the new picture and code
