#include “Arduino.h”
#include “NewPing.h”
#define HCSR04_PIN_TRIG 3
#define HCSR04_PIN_ECHO 2
NewPing hcsr04(HCSR04_PIN_TRIG,HCSR04_PIN_ECHO);
Serial.println(“start”);
menuOption = menu();
if(menuOption == '1') {
// Ultrasonic Sensor - HC-SR04 - Test Code
// Read distance measurment from UltraSonic sensor
int hcsr04Dist = hcsr04.ping_cm();
delay(10);
Serial.print(F("Distance: ")); Serial.print(hcsr04Dist); Serial.println(F("[cm]"));
char menu()
Serial.println(F("(1) Ultrasonic Sensor - HC-SR04"));
while (!Serial.available());
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Testing Ultrasonic Sensor - HC-SR04"));
return 0;
time0 = millis();
return c;
Circuito.io is an automatic generator of schematics and code for off
the shelf hardware combinations.
Copyright © 2016 Roboplan Technologies Ltd.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
In addition, and without limitation, to the disclaimers of warranties
stated above and in the GNU General Public License version 3 (or any
later version), Roboplan Technologies Ltd. (“Roboplan”) offers this
program subject to the following warranty disclaimers and by using
this program you acknowledge and agree to the following:
THIS PROGRAM IS PROVIDED ON AN “AS IS” AND “AS AVAILABLE” BASIS, AND
WITHOUT WARRANTIES OF ANY KIND EITHER EXPRESS OR IMPLIED. ROBOPLAN
HEREBY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING BUT
NOT LIMITED TO IMPLIED WARRANTIES OF MERCHANTABILITY, TITLE, FITNESS
FOR A PARTICULAR PURPOSE, NON-INFRINGEMENT, AND THOSE ARISING BY
STATUTE OR FROM A COURSE OF DEALING OR USAGE OF TRADE.
YOUR RELIANCE ON, OR USE OF THIS PROGRAM IS AT YOUR SOLE RISK.
ROBOPLAN DOES NOT GUARANTEE THAT THE PROGRAM WILL BE FREE OF, OR NOT
SUSCEPTIBLE TO, BUGS, SECURITY BREACHES, OR VIRUSES. ROBOPLAN DOES
NOT WARRANT THAT YOUR USE OF THE PROGRAM, INCLUDING PURSUANT TO
SCHEMATICS, INSTRUCTIONS OR RECOMMENDATIONS OF ROBOPLAN, WILL BE SAFE
FOR PERSONAL USE OR FOR PRODUCTION OR COMMERCIAL USE, WILL NOT
VIOLATE ANY THIRD PARTY RIGHTS, WILL PROVIDE THE INTENDED OR DESIRED
RESULTS, OR OPERATE AS YOU INTENDED OR AS MAY BE INDICATED BY ROBOPLAN.
YOU HEREBY WAIVE, AGREE NOT TO ASSERT AGAINST, AND RELEASE ROBOPLAN,
ITS LICENSORS AND AFFILIATES FROM, ANY CLAIMS IN CONNECTION WITH ANY OF
THE ABOVE.
