I am trying to figure out how to change the circuit builder so the motors and solenoids run through the relays.
Is the builder not able to utilize the relays on the 4 relay board?
It’s not possible to run the solenoids through the relay in the app. The relay and solenoid valve can be controlled with the transistor, eliminating the need for a relay. Maybe you can explain what you’re trying to do so we can have a better understanding of the logic behind this type of wiring and assist you further.
I have different solinoids and motors that i want to run through the relays. Do you have any item in the list that run through the relays?
