How servo motor work
I am making a project on servo motor so please help me out how to join it with Arduino and how to do coding
Hi shashank,
to connect servo with arduino you need just connect voltage and ground and on cable data
data cable must to be a PWM pin, because servo need 20 micro second to change the angle
example: if you give for servo 1.5 micro sec high voltage then 18.5 micro low voltage the servo will go to 0 degree and if you give 2 micro high and 18 low will go to 180 degree .
put in arduino you can use a servo library and connect with PWM pin and just in code put your angle and the srevo moved.
i wish that can help you.
