Iot home using esp8266
IOT HOME USING ESP8266
code:
//Google Assistant Home Automation
#include <ESP8266WiFi.h>
#include “Adafruit_MQTT.h”
#include “Adafruit_MQTT_Client.h”
#define Relay1 D1
#define Relay2 D2
#define Relay3 D3
#define Relay4 D4
#define WLAN_SSID “JioFi2_CD6058” // Your SSID
#define WLAN_PASS “sce2dgvhcj” // Your password
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER “io.adafruit.com” //Adafruit Server
#define AIO_SERVERPORT 1883
#define AIO_USERNAME “username” // Username
#define AIO_KEY “AIO key” // Auth Key
//WIFI CLIENT
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Subscribe Light1 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME"/feeds/Relay1"); // Feeds name should be same everywhere
Adafruit_MQTT_Subscribe Light2 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME “/feeds/Relay2”);
Adafruit_MQTT_Subscribe Light3 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME “/feeds/Relay3”);
Adafruit_MQTT_Subscribe Light4 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME “/feeds/Relay4”);
void MQTT_connect();
Serial.begin(115200);
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
pinMode(Relay3, OUTPUT);
pinMode(Relay4, OUTPUT);
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println();
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
mqtt.subscribe(&Light1);
mqtt.subscribe(&Light3);
mqtt.subscribe(&Light2);
mqtt.subscribe(&Light4);
MQTT_connect();
Adafruit_MQTT_Subscribe *subscription;
while ((subscription = mqtt.readSubscription(20000))) {
if (subscription == &Light1) {
Serial.print(F("Got: "));
Serial.println((char *)Light1.lastread);
int Light1_State = atoi((char *)Light1.lastread);
digitalWrite(Relay1, Light1_State);
if (subscription == &Light2) {
  Serial.println((char *)Light2.lastread);
  int Light2_State = atoi((char *)Light2.lastread);
  digitalWrite(Relay2, Light2_State);
if (subscription == &Light3) {
  Serial.println((char *)Light3.lastread);
  int Light3_State = atoi((char *)Light3.lastread);
  digitalWrite(Relay3, Light3_State);
if (subscription == &Light4) {
  Serial.println((char *)Light4.lastread);
  int Light4_State = atoi((char *)Light4.lastread);
  digitalWrite(Relay4, Light4_State);
void MQTT_connect() {
int8_t ret;
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT… ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) {
Serial.println(mqtt.connectErrorString(ret));
Serial.println(“Retrying MQTT connection in 5 seconds…”);
mqtt.disconnect();
delay(5000);
retries–;
if (retries == 0) {
while (1);
Serial.println(“MQTT Connected!”);
