Mpu 6050 sd data logger - I want to increase the writing speed to the sd card
I am able to get only 200hz write speed . An increase in write speed of atleast 500hz will help in my project.
thanks
I WAS NOT ABLE UPLOAD CODE_ sorry
//Codice scrittura solo dati accelerometro
//sostituiamo con i micros() i millis()
#include <SPI.h>
#include <SdFat.h>
#include <Wire.h>
#define SerialMonitor Serial
#define ARDUINO_USD_CS 10 // uSD card CS pin (pin 10 on SparkFun GPS Logger Shield)
#define MAX_LOG_FILES 100 // Number of log files that can be made
char logFileName[13] = “gpslogXX.csv”;
// Data to be logged:
#define LOG_COLUMN_COUNT 7
#define LOG_COLUMN_HEADER
“time,” “Acc.Z,”
#define LOG_RATE 1000 // Log every n microseconds
unsigned long lastLog = 0; // Global var to keep of last time we logged
const int MPU=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ;
double z;
// SD definition
SdFat SD;
File dataFile;
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
SerialMonitor.begin(9600);
updateFileName(); // Each time we start, create a new file, increment the number
 // see if the card is present and can be initialized:
 if (!SD.begin(ARDUINO_USD_CS))
SerialMonitor.println( F(“Error initializing SD card.”) );
} else {
dataFile = SD.open( logFileName, FILE_WRITE );
// Print a header at the top of the new file
dataFile.println( F(LOG_COLUMN_HEADER) );
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU,14,true); // request a total of 14 registers
AcX=Wire.read()<<8;
AcX|= Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8;
AcY|=Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8;
AcZ|=Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
// GyX=Wire.read()<<8;
// GyX|=Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
// GyY=Wire.read()<<8 ;
// GyY|=Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
// GyZ=Wire.read()<<8;
//GyZ|=Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
if ((lastLog + LOG_RATE) <= micros()) {
z=AcZ/16384.00;
printImuData(dataFile,lastLog,z);
dataFile.flush();
lastLog=micros();
static void printImuData(Print &printer, unsigned long lastLog,
int16_t AcZ
{//Printing the mpu6050 information
printer.print(lastLog); printer.print(",");
// printer.print(AcX); printer.print(",");
// printer.print(AcY); printer.print(",");
printer.println(z,7); // printer.print(",");
// printer.print(GyX); printer.print(",");
// printer.print(GyY); printer.print(",");
// printer.println(GyZ);
// updateFileName() - Looks through the log files already present on a card,
// and creates a new file with an incremented file index.
void updateFileName()
for (uint8_t i; i < MAX_LOG_FILES; i++)
// Set logFileName to “gpslogXX.csv”:
logFileName[6] = (i/10) + ‘0’;
logFileName[7] = (i%10) + ‘0’;
if (!SD.exists(logFileName))
break; // We found our index
SerialMonitor.print(logFileName);
SerialMonitor.println( F(" exists") );
SerialMonitor.print( F("File name: ") );
SerialMonitor.println(logFileName);
Hey Jeos,
I came accross this thread on Arduino.cc, you might be able to find an answer inside.
You can also look at the SDFat lib github repo here, there are several speed configurations you could play with.
Good Luck!
Ohad
