I have a system where a RFID is making 2 servo motors move 180 degrees. But at the moment I have a delay for the motors and I don’t know how to have the motors on wile the card is present and when the card is removed the motor moves to its original position (0 degrees).
thanks
Hi, can you share the code you are working on ?
Maayan
This is my Code:
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_G 4 //define green LED pin
#define LED_R 5 //define red LED
#define BUZZER 2 //buzzer pin
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Servo myServo1; //define servo name
Servo myServo2;
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
myServo1.attach(3); //servo pin
myServo1.write(0); //servo start position
myServo2.attach(6);
myServo2.write(180);
pinMode(LED_G, OUTPUT);
pinMode(LED_R, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
Serial.println(“Put your card to the reader…”);
Serial.println();
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print(“UID tag :”);
String content= “”;
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " “);
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0” : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.println();
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == “41 A3 DE DB”||content.substring(1) == “D5 64 BF B0”) //change here the UID of the card/cards that you want to give access
Serial.println(“Authorized access”);
Serial.println();
delay(500);
digitalWrite(LED_G, HIGH);
tone(BUZZER, 500);
delay(300);
noTone(BUZZER);
myServo1.write(180);
myServo2.write(0);
delay(5000);
myServo1.write(0);
digitalWrite(LED_G, LOW);
else {
Serial.println(" Access denied");
digitalWrite(LED_R, HIGH);
tone(BUZZER, 300);
delay(1000);
digitalWrite(LED_R, LOW);
noTone(BUZZER);
Hope to hear back from you and/or others
