Hey guys!
I am a 3D Artist and a Electronic stuff beginner !
I gonna buy a transistor , I created a simple design in circuito.io app.It says N-Channel MOSFET 60V 30A!
the question is can I put a transistor with more Voltage like 100 or something? would not hurt?
THX
Hi!
The design you have is built around a MOSFET, you could probably use a higher spec MOSFET, of course it depends on the actual MOSFET you’ll use.
If you plan to use other kinds of transistors then the design would need to be modified as well.
Read more about BJT vs MOSFET
Cheers!
