VL53L0X Time-of-Flight Laser Distance Sensor
Hello, it is possible to measure distance with VL53L0X Time-of-Flight Laser Distance Sensor to two decimal places? Thank you
Hello,
Two decimal places in what units?
The VL53L0X range resolution is in millimeters.
if you want to print two decimal places of a millimeter - this sensor doesn’t suit you. Other than this, it is only a problem of representation in the code.
Thank you for you answer, and which sensor is suit to my application? I need measure distance to two decimal places (in one point). I make machine to measure the samples for tensile test. Thank you.
And units is milimeters.
