I want to create a device that saves water but im very bad at coding. PLs help
How it works:
-the user will turn on the device with a switch. (switch)
-a different password is pressed to run different programming code (keypad)
- the water will run for 5min before the solenoid valve shuts off. (solenoid valve)
 - 30 secs before the valve shuts, an LED will light up to indicate to the user that time is almost up. (LED)
 - the solenoid valve will turn on again after 30 secs for 1minute before shutting off again. ( should be in the loop section of programming?)
 - programme will reset when power is turned off
