We’re adding new components all the time!
In this thread, you can suggest the components you want to see on circuito.io and we will add them to our special wishlist
Hi Sathees, thank you for your great component suggestions, we’ve added them to our component wishlist.
Do you have any Adafruit Feather controllers for circuito.io?
I would like to see DFRobot ‘Romeo BLE Mini’ added to controllers. This has ble on board and also motor shield on board, based on UNO
In components I would like to see:
A specific button for ‘ON’ with code already included. With link to item that is wanted ‘ON’
A specific button for ‘OFF’ with code already included. With link to item that is wanted ‘OFF’
Maybe you have a Button: ON - Motor
Another for: Button: ON - LED Blue
Another for: Button: OFF - LED Blue etc etc or some way of connecting the button and the device.
Another set of buttons similar to above for motor direction control:
Button: Reverse Motor
Button: Forward Motor
Button: Stop Motor
and for speed control, a slider or a pot for:
Slider for Motor Speed: 28 (or steps selectable) steps 0 to max
Last one, a button to say that the incoming data to arduino is coming from BLE, not from on board hardware. Circuito would then set up accordingly (with correct code)to get from BLE. A test function for BLE would have to be set up by say entering the info in terminal that would normally be sent, something like ‘Forward 1’
Been searching for 2 years for something like Circuito and now found it. You probably need to let the multiple Arduino community know it, or have your IT people set up
Thankyou
A specific button for ‘ON’ with code already included. With link to item that is wanted ‘ON’ Google Meta Data, so that circuito shows up more easily.
Charles Harris
Hi! Would be nice to have some audio amplifiers. I would like this one in particular:
Adafruit Mono 2.5W Class D Audio Amplifier - PAM8302
Thanks!
Makey Makey is an arduino and has these little things to connect, and when they are connected, everytime they touch the earth, it activates an effect. Also it has these little squares that are named “arduino”, so it’s also arduino supported
Hello, i world like to have a component that heats water flowing in a plastic tube to approximately 40 degrees, it could be like a water flow sensor G1/2.
I really want you guys to add Turbidty* sensor, Raspberry PI camera , pH sensor. Can you add this on coming days?
You mentioned the A4988 in another post as if reading my mind, please add this wonderful alternative component
Xbee S-1 RF transmitter/Reciever
The following Adafruit Feather microcontrollers would be awesome:
WICED Feather
HUZZAH ESP32 Feather
Bluetooth 32u4 Feather
Radiofruit 32u4 Feather
Hi everyone, thank you so much for all your wonderful suggestions.
Soin we’ll be adding an option for users to submit their own components! If you want to help us bring new components to circuito.io and give a great gift to our community, please send me a private message or email me - [email protected] and I’ll fill you in on all the details.
could you add Grove - Speech Recognizer
https://store.arduino.cc/usa/grove-speech-recognizer
https://store-cdn.arduino.cc/usa/catalog/product/cache/1/image/520x330/604a3538c15e081937dbfbd20aa60aad/c/o/cover_2_.jpg
Liquid PH0-14 Value Detect Sensor Module + PH Electrode Probe BNC for Arduino
MAX 30100, Max 30101,Max 30102, SFH 7050. Thanks in advance!
ZMPT101B is a must for home automation project as it is used to measure AC voltage up to 220.
