Suggest a component
Non Invasive AC current sensor 100Amps
9V lithium Ion and Lithium Polimer Battery
The a4988 stepper driver would be awesome to get.
Buenos días!! Podrían agregar Bluetooth_Shield_V2 con sensor de temperatura. Espero sus comentarios.
But then, maybe not…
Please add:
Adafruit VL6180X Time of Flight Distance Ranging Sensor
Thanks!
Hello, please add a pH sensor and raspberry pi 4:
https://atlas-scientific.com/circuits/ezo-ph-circuit/ <—Link of the pH sensor
https://www.amazon.com/Raspberry-Model-2019-Quad-Bluetooth/dp/B07TC2BK1X/ref=sr_1_3?crid=W6W86GGCLNNI&dchild=1&keywords=raspberry+pi+4&qid=1604426420&sprefix=Rasp%2Caps%2C235&sr=8-3 <— Raspberry pi 4
please add this component
voltage sensor module
temperature sensor max 31855
thank you in advance
ne555 timer ic
18650 batteries and holder
bo dual shaft gear motor
can you make transistors, resistors and capacitors seperately other than with other parts
Hello,
I’m new to this and am looking for a 8 channel relay. Any chance this can be developed.
Thanks in advanced
Please add photo electric sensor
Thank you for this amazing project!
Could you please consider adding a logic level shifter like one of these?
SparkFun Logic Level Converter - Bi-Directional - BOB-12009 - SparkFun Electronics
I would like to see an MD10C motor driver
, and a 12V reversible worm gear motor.
it would be helpful for me if i can get Rain sensor and Rain sensor module components.
Hello
I suggest the 16 channel mux CD74HC4067
