Could you add a PCA9685 12-bit 16-channel PWM driver?
first love the app. makes my life so much easier⦠also can you add a multiplex chip into the software⦠idealy
IC 74HC595 74595 SN74HC595N 8-Bit Shift Register DIP-16
many thanks
Would it be possible to add the Tranceiver from
Thatād be awesome.
me too!
I want a sim 900 gsm
Can you please add new component AD9850 DDS DSP SIGNAL GENERATOR MODULE 0-40MHZ SINE WAVE?
I think this fingerprint sensor is different from the already existing fingerprint sensor in the components list. So please add this item too. I want to use this item in my project and it has to be submitted within this month. So I hope, you could add this item to the components list earlier as possible and please inform me through email if possible.
i like to see RC FS-CT6B TH9x reciever for my circuit.
I wish you add some camera components like OV7670 Camera Module for example
Hello, I hope Iām in the right place. I am currently adding a few PZEM-004T-100A V3.0 voltage/current/power/frequency/total power/power factor meters to an ESP-8266 project Iām working on and thought it would be worth creating a model for Circuito. I will be using the Arduino library for the Updated PZEM-004T v3.0 Power and Energy meter on github by Mandulaj. I think this component would make an excellent nomine for inclusion in our bag of toys. Thanks for your consideration.
4 suggestions. Arduino Nano33 iot,Nano Every, Nano BLE sence and the Nano BLE . Thanks for this great tool!
Plz add ov7670 camera module as soon as possible!
Osepp Uno Max
Hi. I am a Biomedical engineering student. i wanted some sensors listed below to be updated here.
1.AD8232(ECG Sensor)
2. RKI-2401 (EMG Sensor)
Infrared Water Liquid Level Sensor Control Switch at eBAY
Material: PC
Measuring accuracy:1MM
Current output:15mA
Power voltage: 5V
Features:
No mechanical moving parts, high reliability
High precision level control
RoHS compliant
Easily mounting method with locking nut
Equipped with 50 cm cable length
Hello! Would you consider adding this, please?
Hello,
I would suggest SparkFun I2C DAC Breakout MCP4725
and Shield MKR CAN ASX00005.
Iāve been trying to add them myself through the component editor and despire my best efforts, I can manage to add it succesfully to my circuit in the preview.
Please add these two things and a option to download a screenshot of your projects in high resolution so you can see what pins go were
SN74141 IC chip
IN-8-2 nixie tube
GIKFUN Capacitive Moisture Meter - Iām using these analog meters for gardening
UCTRONICS OLED module - I find these small (.96") I2C modules work well with the Arduino Nano
A Camera please any camera would do
