Could you also add MLX90365 Triaxis Position sensor?
It would be great to have some Melexis sensors in component list.
I need them for my Thesis
hola, podrían poner estos elementos por favor uwu
Cnc Shield Arduino Nano V4 Ruteadora Maquina Corte Drv8825
Módulo Shield Pca9685 Pwm 12bit Driver I2c Controla 16 Servo
Nema 17 Motor Bipolar 83.6oz.in 40ncm Impresora 3d W01
modulo bluetooth hc-06
hi. i really hope you can add some Electrical conductivity sensor, pH sensor in circuit.io thank you:grin:
please add DTMF decoder in circuito io.
Please add BBC micro:bit in circuito.io
https://www.microbit.org/
https://tech.microbit.org/hardware/
Ooh the micro:bit - it’s such a tiny board!
EDIT: You can buy the micro:bit on Adafruit here:
Hi Niel
If you’ve looking for programming resources for the micro:bit (uBit), these links might be helpful:
- Getting started: https://os.mbed.com/platforms/Microbit/
- Documentation: https://lancaster-university.github.io/microbit-docs/ubit/
- Simple online coding (Blocks (much like Scratch) or JavaScript) including simulation in the browser!: https://makecode.microbit.org/?lang=en#editor
- Advanced online coding (without simulation): https://ide.mbed.com/compiler/#nav:/;
Hope that helps
Here’s a great one from Adafruit
The Teensy 3.2
GY-521 (MPU-6050)
Micro SD Card Slot
N-Channel Mosfets
120ohm Resistor
100ohm Resistor
Thank You!
Waterproof JSN-SR04T Ultrasonic Distance Sensor
Add GSM 900 A. Please it is very important we have a NATIONAL LEVEL PROJECT
You can do it using a GitHub account.
Link to Gitpod(you use your GitHub account to log in)
I just saw your other post “2 remote servo control remote” and thought bhofmann could help with this.
who sir ?? any contact details please …or link pls
“slaps head” I’ll call him now. @bhofmann (sorry I know we talked about this)
I’d like a capacitive soil moisture sensor. Adafruit - Capacitive Soil Moisture Sensor
MAX6675 module and a k type thermocouple.
I would like to see the BLE Nano added here and also the ability to just use a battery pack for power like this one. The links are below.
Thanks,
Dustin
could you please add a Power supply module!
image|225x225
